Thread: Porch Floor
    Question Porch Floor
    I have a 82 yr. old covered porch tongue and groove floor over a basement. There are periodic water leaks into the basement and the borads are rotting and buckling and need replaced.
    What is the best way to install a new floor and have it waterproof? The original floor just looks to be a 1x8 base with the 3/4" T&G flooring. There is 2 1/4" between the joists and the bottom of the front door.
    Any help is appreciated!!!
    TOHDIY in Ohio
    Default Re: Porch Floor
    Check out this thread http://advice.thisoldhouse.com/showt...orch+cleveland and see if it helps.
