    Sep 2011
    5
    Default Under house crawl space
    Should under the house be insulated?
    Nov 2011
    Charlotte, NC
    12
    Default Re: Under house crawl space
    Well, yes.
    Most State Codes require it now. Fiberglass in the joists is better than nothing.
    If it's not a vented crawl space, insulating the walls with a rigid foam board or a 'curtain wall' (fiberglass insulation wrapped in a thick poly) are good options.
    Spray foam is available, i'm just not a fan.
    Helping Homeowners understand the Typical Causes and Solutions to Hidden Content issues!
