    Tennessee
    1,974
    Default Would a third coat hurt?
    My daughter has a new house, well its about three years old now but she bought it new. She wants to add gutters. The gutter company told her they would have to remove the thin strip of wood at the top of the fascia board so the gutters would mount flat to the fascia.
    they didn't say anything about painting the bare wood left, they don't do painting. So the last two weekends, I have removed this trim strip and have put on two coats of the best Valspar paint from Lowes. I did a light sanding of the contractor paint before painting.
    Once the gutters go on, this will not be accessible again. Would it hurt to put on a third coat of paint?
    I am going to paint the rest of her house shortly, not that the contractor paint has worn away yet, I want to do it before it is needed. Would it hurt to put three coats on the remaining fascia boards since they get more wear and tear from the elements?
    7,927
    Default Re: Would a third coat hurt?
    Two should be sufficient.
    1,522
    two is fine, especially in spots that are going to be covered up by the gutters. i wouldnt worry about it to much
    1,917
    If the gutters are hung and flashed correctly, the bare exposed wood on the fascia board will never see water and need not be painted at all. However, it certainly does not hurt to paint it.
