    Sep 2011
    Default Shallow well pumps problems
    Hello, We have a spring on our property that is the water supply for our home and some of our farm animals. The spring gravity feeds into a pump house with a cistern, then the pump sends the water up to the house. Our problem is, occasionally, my husband will turn on the water to fill the animal tank and forget he has turned it on. Of course, the cistern gets too low and the pump ends up running without any water which damages the pump. Is there any kind of device we can attach to our new shallow well pump that will automatically shut if off when there is no water moving through it? Also, sediment is a problem with the pressure switch. It gets sediment stuck in it at the diaphram, I think, and won't send a signal for the pump to engage. Is there something that will take care of keeping the sediment out of the switch? Thanks!
    South*East
    1,257
    Default Re: Shallow well pumps problems
    There is a pressure switch that will not allow the pump to run with low pressure. When pump stops pumping and the pressure drops it will cut the power to the pump, until you reset switch.
    http://www.plumbersurplus.com/Prod/S...12016/Cat/1446
    John
    6,080
    Another possibility is to install a float switch in line with the pump. A float switch would not need a manual reset.
    As for the sediment, you might want to install a cartridge filter in the line.
    Jul 2009
    Northeast
    661
    Yep what JL said, a float switch is probably the easiest surefire solution.
    South*East
    1,257
    Quote Originally Posted by Sten View Post
    Never gave that a thought. That would be a better solution. The pressure switch I referred to is used more for submersible pumps in wells with slow recovery.
    John
