Page 2 of 2 FirstFirst 12
Results 11 to 11 of 11
  1. #11
    Mar 2013
    WI
    112
    Default Re: Repainting Metal Kitchen Cabinets
    "Yes you can use metal cabinet.If you buy new cabinets then setting up these units starts by preparing the areas first. After the old models are out, fix every factor of the places that will not be properly secured by new models. This stage is best done when there are no models on the places, because doing this after your new models are set up is quite complicated. Then, you have to consider how excellent you want to set up the having models, calculated from the end cupboard."
    Huh?
