    Sep 2011
    Question New lighting fixtures...
    Have very simple new lighting fixtures to install in my condo. When I got into the box there is a message on the fixture to the following...
    MIN 90 DEGREE CELSIUS SUPPLY CONDUCTORS
    CAUTION: RISK OF FIRE. MOST DWELLINGS BUILT BEFORE 1985 HAVE SUPPLY WIRE RATED 60 DEGREE CELSIUS. CONSULT A QUALIFIED ELECTRICIAN TO ENSURE CORRECT BRANCH CIRCUIT CONDUCTOR.
    Is this something that I can check, or do I have to have an electrician come in to do it?
    (My condo was built around or before 1985.)
    Jan 2011
    Columbiana, Alabama
    712
    Default Re: New lighting fixtures...
    CC, just run the fixture wire into the box in your ceiling to make the connections.
    Maurice Turgeon, http://thesemi-retiredelectrician.com
    Sep 2011
    Question Re: New lighting fixtures...
    So just go ahead and follow the regular instructions that came with the new ceiling lighting fixtures?
    6,539
    Yes.
    The caution sign is there as a warning, but if you connect correctly, you'll be fine.
    1,611
    The label was most likely ordered by their insurance company and written by their lawyer. It means you can't sue them if your house burns down.
