    Sep 2011
    Default wood wainscoting installation
    Installing wood tongue in groove wainscoting in my kitchen. Came to an electrical outlet and will have to address two more. How do I make a nice rectangular hole for the outlet and faceplate?
    1,375
    Default Re: wood wainscoting installation
    Jigsaw would be the tool of choice. You need to execute good measuring skills to get the hole in the right place. If the hole is in the center of a board, you will need a 3/8" drilled hole to start the cut.
    Casey
    1,522
    if there is space to hold the peice directly next to the outlet you can actually mark and scribe the outlet in place
