Thread: Amperage Issue
    Sep 2011
    Default Amperage Issue
    If the breaker is 20A and the wire is 12 gauge, must I use 20A outlets - or can I use 15A?
    Columbiana, Alabama
    792
    Default Re: Amperage Issue
    If you just connect one receptacle to the breaker it must be rated for 20A. If you connect more than one they can all be 15A.
    Maurice Turgeon, http://thesemi-retiredelectrician.com
