Results 1 to 8 of 8
    Sep 2011
    Default Plug a bathroom vent
    Due to noise and smoke from upstairs neighbor (live in apartment building), I want to plug up the vent fan opening in our bathroom. We have other means of venting the steam during showers.
    QUESTION: What material would work best? I only want to remove the fan grate and plug the hole in the wall (approx. 12" x 12"), in a manner that I could "undo" if/when we decide to move from the apartment. I was thinking acoustic tile over a piece of plywood. Any suggestions?
    Thanks.
    Default Re: Plug a bathroom vent
    I would recommend Saran wrap over the vent grill, that way you won't forget to reverse it when you leave and it won't be an issue for the next tenant.
    Sep 2011
    Saran wrap won't block noise. And based on an earlier attempt with painter's plastic (plastic floor covering sheets), I don't think it would block the noxious odors we're getting from those %(#&)(Q folks upstairs.
    Oct 2008
    116
    What about a piece of 2" thick foam insulation (or some thick craft foam from a craft store), cut to fit the vent?
    Good luck.
    There's not much you're going to be able to do to block the noise. Stuffing the vent with foam may help slightly, but if they're making enough noise to be transmitted through the vent, they're making enough noise that's going to be transmitted through the floor/ceiling as well.
    Your best be may be to find a new apartment in a smoke free environment.
    Sep 2011
    The noise issue through the vent is simply that they run the vent fan practically 24/7. I just want to make it so we don't hear the roaring of their vent fan.
