    Mar 2010
    5
    Default removing interior basement wall
    My basement is wide open except for one corner where a previous owner put up two walls, making a "hobby room" in the basement. I want to take that wall out to open up that corner for a pool table. The wall I want to remove runs along the load-bearing beam. The steel supports are still there. So I'm thinking this wall is not load-bearing and I can just remove it, while leaving the supports. Is that correct?
    (I tried to attach pictures but it doesn't want to let me.)
    Thanks
    -matthew
    Default Re: removing interior basement wall
    Typically there will be support columns along the inner span of a main support beam --- commonly you'll find two columns --- up to a 40 ft running length ( more on longer runs ) --- giving 3 equally spaced open sections . As long as these cloumns are sitting on proper footings ( not just resting on the floor ) chances are the wall you mentioned is not a suporting structure and can be removed.
    If you're unsure then get some advice from a professional contractor or engineer.
    1,522
    im with canuk. you should get an engineer or contractor to look at it.. though the support post should be supporting the beam there and the wall was put in place just to create a little more privacy.
    however there is a slight chance that something was done wrong so the point load was moved. best to have a trained eye look at the overall picture
    Never assume anything about previous owner's actions.
    Consult a professional, like canuk and jkirk suggested - that will be the best money you've ever spent.
    Mar 2010
    5
    Thanks for the replies.
    I'll contact a professional to take a look at it.
    -matthew
    1,522
    teh last thing you want is to have a structural failure with your house
