    Aug 2011
    Default Basement bathroom
    Hi,I have a bathroom in my basement that during extreme weather and very heavy rainfall the drain in my shower and my toilet bowl has water backup causing flooding.Light rain is not a problem. Just got bad back flow during hurricane Irene. What should I do to fix the problem?
    Default Re: Basement bathroom
    Sounds as though you need a backwater valve such as this
    http://www.backwater-valves.com/
    3,155
    How often do you have a flood?
    If your place floods once a decade or greater, I'd consider pulling the toilet before the flood, installing a drain plug then replacing the toilet after the flood. The plug costs $8 the wax ring $1
    Houston ---- What if you're not at home when a rainstorm hits ?
    Around here it's been code for about 20 years to have a backwater valve on the home main waste line. On older homes it's code to install one if a basement bath room is being built.
    3,155
    Usually there is some warning ahead of time that a storm's a brewin'
    7,627
    I believe that a backflow preventer is required when the lowest drain point out of the house is 2' or less above city sewer line.
    In that case, the homeowner can rest assure that his backflow preventer will stop all that stuff from entering the house. Similar to anti siphone valves used in sprinklers.
