    Nov 2010
    10
    Default Piggybacking security light onto ceiling fan
    Hello all.
    I'm looking to install a motion sensor light on the outside of an enclosed sunroom. It appears that the closest wiring is at the sunroom's ceiling fan, so I was thinking about piggybacking onto it, then running the new wiring to the outside of the house.
    Does this sound like a reasonable option? To keep the security light on, I'm assuming I would have to leave the light switch to the fan on all the time, then just operate the fan with the pull chains.
    I don't have a lot of electrical expertise - mostly replacing light fixtures and such. I've never dealt with ceiling fans before.
    Also I'm unsure of the best way to route the wiring to the security light. I think I could go up above the sunroom ceiling, but I'm not sure how much space is there.
    Thanks for any replies.
    6,116
    Default Re: Piggybacking security light onto ceiling fan
    That's a hard question to answer with the information provided. We don't know how many wires you already have in the fan ceiling box, and code prescribes limits, we don't know if you have full time power in the ceiling box or just switch supplied power to the fan, we can't see the installation so how can we advise you how to run the wires.
    Jan 2011
    Columbiana, Alabama
    843
    Matt, a ceiling fan/light is not the place I would go to get power. They are crowded, hard to access and you would have to either try to work between the blades or remove some.
    Then support the fixture with a wire or rope, if it doesn't have a maintenance hook.
    I would go the closest light switch that only had two wires in the box which means the light has constant power. If you can get in the space above (like an attic) it would be a good candidate to borrow power.
    Be sure to mount the motion light/sensor on a weather proof box, people who don't are called victims of a fire.
    Maurice Turgeon, http://thesemi-retiredelectrician.com
    Dec 2011
    We are in desperate need of help! We are trying to install a ceiling fan with a light kit and a wall switch that control both the light and the fan separately. The problem is that we have three wires plus the ground coming from the ceiling instead of the two wires and ground stated in the instructions.
    Quote Originally Posted by cashmart35 View Post
    Is the ceiling location an existing light or is it newly wired? Is this light on a 3-way switch, meaning that it is operated from two separate switches? Will the ceiling location support the weight of a fan?
    The additional wire is probably going to the switch.
    Try to attach a photo.
    240
    MattB2517, as an alternate would you consider running conduit outside so you have more flexibility and an easier time pulling wire from a different location? If there is an exterior wall near the proposed location that would be more accessible if a conduit with a specific type of wire is run?
