Thread: Glider
    Jul 2011
    14
    Default Glider
    I have a glider and noticed it wasn't working correctly. I was taking it apart and noticed that three of the five heads of the screws holding the leg to the glider were broken about and 1/8" below the flush surface of the leg. I tried to tap the screw using a drill it would not come out. Is there a tool I can use to remove the broken screws from the leg without it being noticed on the finished side of the leg. Thanks
    Default Re: Glider
    Get yourself a set of screw extractors, one of them will get your broken screws out. The set is really inexpensive.
