    Sep 2009
    9
    Default New ceiling fan - code requirements
    I am installing a celing fan in our nursery (i am doing a gut remodel on the room) and have a question regarding code requirements.
    Currently, our nursery and master bedroom open directly into the living room with the stairs (that lead to the second floor) between the two entry doors. However, there is also a door between the nursery and master bedroom at the back end of each room.
    Do I need a three-way switch (for the celing fan) at the door between the master bedroom and nursery?
    7,756
    Default Re: New ceiling fan - code requirements
    You can do whatever you like in this situation. You are only required to have a light switch at the primary entrance to the room.
    Sep 2009
    9
    Ok, thanks...
