    Aug 2011
    Question Cracking Exterior Grout *between bricks)
    We live in a 50+ yr old brick home. And the grout is cracking and separating from the brick. How do we go about doing the repairs?
    3,201
    Default Re: Cracking Exterior Grout *between bricks)
    The stuff between the bricks is called mortar. Are the cracks general or seem to follow a straight line? Cracking mortar is usually a sign of foundation issues.
    Where is your house located? Are foundation repairs common?
    Aug 2011
    5
    The process you're referring to is called "repointing" and there's actually a pretty good article by Danny Palousek on the ThisOldHouse site. (Sorry I can't link to it because I don't have link privileges on this forum yet!) You can Google: "Danny Palousek repointing" and it'll show up.
    Hope that helps a bit.
    Aug 2011
    Thanks for the reference to article. I saw a segment on TV not too long ago, in regards to putting clear caulk in the cracks.
    Houston Remodeler--I did check w/a structural engineer, and not a foundation problem. We had double pane windows installed a couple of years ago, and I noticed that this problem was occurring. So central TX has an extreme drought happening this summer. And the bricks are not cracking, which would also indicate a foundation issue.
