    Aug 2011
    Default What is this part?
    I have double-hung wood windows on my house circa ~ 1950. There is a part that screws to the frame that holds the storm window in place. One end of it broke, so I need to replace the part. I've been to all the popular hardware stores in my area (Home Depot, Menards, Lowes), and a couple local shops. No one has it, much less knows what it is called. It's aluminum, and has a plastic piece on each end that the storm window slides on. For the lack of a better term, I would call this thing a tension spring. It basically holds the sliding storm window against the other screen/storm window.
    #1) What is this part called?
    #2) Any suggestions where it can be found?
    Thanks in advance for the help anyone can offer. I'm stumped.
    Philip
    Images below. The part is originally bare aluminum; it's painted brown in these photos.
    picasaweb.google.com/111609289486835675821/WindowPart#5642618136854563826
    picasaweb.google.com/111609289486835675821/WindowPart#5642618132304599330
    picasaweb.google.com/111609289486835675821/WindowPart#5642618133090592194
    1,203
    Default Re: What is this part?
    links don't work.
    Aug 2011
    Sorry -- links updated.
