    Aug 2011
    Default visable screws on stair treads
    Just removed the runner from the stair case in our 1920's home.
    Hoping to refinish the stairs along with the floors. We found 2 screws in the center of each step, probably to stop squeaking.
    How do we cover the screws or remove & fill the holes so we can refinish & leave the stairs uncovered?
    1,522
    Default Re: visable screws on stair treads
    if the stair treads are screwed down they should be countersunk and counterbored, then the remaining portion of the hole filled with a wood plug that matches the wood in the tread.
    i wood back out the screws then counterbore them, install new screws then plug
    1,383
    You could countersink the screws and fill the holes with face-grain wood plugs cut from matching wood. You may as well, since the screw holes aren't going away.
    Repairs can be effected from beneath, but gaining access is usually very painful.
    Casey
    Sep 2011
    53
    fill the holes with wood plugs is a great suggestion
    1,898
    If the screws are uniformly placed on each step, maybe you could replace them with decorative screws and it could be a "feature" instead of a "bug."
