    Jun 2008
    5
    Default cost of installing a new circuit
    I am looking to move our chest freezer down to our basement. There are only two outlets in the basement, and they are being used. I would also like to have a couplw of new outlets installed and I am thinking that a new circuit may need to be run to add more outlets. Perhaps I am wrong, but if I am right, could someone give me a very rough estimate of what the cost would be of having an electrician come in and do this? Thanks!
    Columbiana, Alabama
    843
    Default Re: cost of installing a new circuit
    Cbernard, if the main panel is located within 20 feet of where you would like the two additional duplex receptacles you're looking at a GFCI receptacle feeding the second standard receptacle.
    Material cost would be:
    Permit about $60
    Wire and boxes about $10
    GFCI receptacle and cover about $20
    Standard receptacle and cover about $3
    20A single pole circuit breaker about $8
    3 hours labor & travel, anywhere from $60 to $90/hr
    This assumes romex may be run on the surface.
    Maurice Turgeon, http://thesemi-retiredelectrician.com
