Results 1 to 7 of 7
    18
    Default Garage insulation
    I'm wondering if insulating the attic over my garage would help keep the rest of the house cooler in summer and warmer in winter.
    8,065
    Default Re: Garage insulation
    The separation wall between the house and garage should already be insulated, so adding insulation to the garage won't help the house, but it will help the garage.
    We can only assume that the wall between the interior and the garage is correctly insulated, but depending on the age and location of the house, I won't be surprised that there is no insulation at all. I've seen in many times.
    I would insulate the garage, including the garage door (sectional?) simply to answer the question "what if...?"
    18
    There are two closets next to the garage and I have reason to believe they skipped the insulation there.
    The garage door is insulated and it has been really hot in there this summer.
    1,522
    the wall betwen the house and the garage has to be insulated plus get a vapor barrier, if it wasnt it never would have passed an inspection as the garage is considered "a cold space".. unless it was built before inspections became the norm
    It looks like you will need to insulate 3 of the garage walls and the attic. If the 2 sides of the garage are unfinished, consider finishing it. In the attic through extra insulation.
    A well insulated house will save you money in the long run.
    Aug 2011
    I think I really learned from this site a lot of important information and hope this site will be more to do better.
