Results 1 to 9 of 9
Thread: Chimney caulk
    Aug 2011
    Default Chimney caulk
    Our Chimney was caulked using regular caulk befor we moved in. The caulk has since cracked leaving the brick morter exposed to elements. I have noticed bubbling and peeling of the interior walls on the chimney side of the house. What can we use to A. take caulk off and B to fill back in to prevent moisture from entering the house?
    1,522
    Default Re: Chimney caulk
    it may not entirely be the caulking you could need a new flashing job. you really need a trained eye to look around at it to see any other spots where water is getting in
    6,758
    I would redesign the flashing, as jkirk suggests, and re-caulk where the chimney meets the side of the house (carefully remove old caulk, clean, apply new dupont masonary caulk). It's almost impossible to pinpoint the source of the leak, therefore a complete job is needed.
    Don't fix any water damage until you solve the leak problem.
    Sep 2009
    florida
    598
    Is there a saddle behind the saddle......Saddles were pretty common yrs ago....then it seamed like there was a period where mass development subdivision companys stopped installing them....Im sure it was a cost factor thing........
    http://www.inspectapedia.com/chimney...ftop_Insp5.htm
    Gizmo
    Hidden Content
    Hidden Content
    Aug 2011
    So what type of professional do I need to inspect, roofer or chimney inspection spe******t? I have no idea what a saddle is either so I dont know if we have one.
    1,522
    you should be looking for a chimney guy, they do the flashing work on the chimney. some roofers are capable of doing it but most just deal in the shingles
    Sep 2009
    florida
    598
    JK i cant say Ive seen a chimney guy do flashing in yrs..Maybe on a custom house.......The HVAC/Gutter guys usally did them when I got in the trades...... They seamed the step flashing into the mortor joints then caulked it. Now days the roofers cut the flashing to step down the brick and caulks it.......They dont seam it into the mortor joint...
    Gizmo
    Hidden Content
    Hidden Content
    1,522
    interesting gizmo, must be one of those regional things..
    our chimney guy does all the flashing at teh chimney itself and cuts it into the mortar joint.. the only flashing our roofer does is step flashing going up side walls
    6,758
    Around here roofers do it, since there are less and less custom chimneys being built, you have a hard time finding old time quality chimney guys.
    Builders are putting in other kinds of chimneys.
    Some sheet metal guys and even some experienced framers know how to do it correctly too (as there are many skylights being put in).
