    Aug 2011
    Default ceiling light wiring
    I am replacing a ceiling light that has two separate switches to turn it off and on. There are 2 black wires, 2 white wires, 2 ground wires and a red wire coming out of the ceiling junction box. The new light has 3 wires 2 are for the black and white (not colored or labeled) and one is for the ground. I have tried every combination to wire this light. I can wire it and the light comes on but neither of the wall switches will turn it off. I can wire it and when I flip the switch the breaker trips. Very frustrated.
    Default Re: ceiling light wiring
    Before you start connecting wires, you need to know the hot and neutral on your new fixture - so you don't trip your breaker again.
    Since they are not colored, feel them with your fingers: one will feel smooth (neutral) and the other will feel a little rougher (hot). The exposed copper is your G.
    Now, continue with the connections. First turn off the breaker. Try the 2 blacks and red to the new hot, 2 whites to the new neutral and ground to ground. Use wire nuts big enough for 3 and 4 wires.
    Turn on the circuit breaker and try the switches. Report back.
    6,053
    Just a guess, but with tripping the breaker I think you are wiring all the whites together but one of the white wires is part of a switch loop. First check the wires in the switch boxes and let us know what you have. Do no experiment with connections until you have more information. Do you have a volt meter?
