    Jul 2011
    14
    Default Adding a light switch
    Have a question? I would like to add a light switch to the entrance way going into my garage. I have a existing light switch going from the house to the garage. It would make life a little brighter.
    7,597
    Default Re: Adding a light switch
    To install a second switch onto an existing light circuit, you'd have to change the other switch and wiring to accommodate what's known as a 3-way switch circuit. If you've got access to the wiring, this isn't an overly difficult thing to do. If you have no access, then you may want to change the switches out to remote switches, then there is no need for new wiring.
