Results 1 to 10 of 12
    Aug 2011
    Unhappy 14" rough in and require a small toilet
    I decided to surprise my husband with a bathroom remodel while he was out of town. He came home to find a bathroom with no sink and no toilet. Apparently I destroyed the only toilet in the world that fit the space. We have a 14" rough and the small space allows for only a 26" depth from the wall. I have spent hours on-line trying to find a toilet with no success. My husband insists the adapters that would allow the use of a 12" rough in do not work well. Does anybody know of any options?!?
    6,736
    Default Re: 14" rough in and require a small toilet
    One solution is to find out who manufactured your toilet and contact the company. Look for a stamp or a name in the tank or the bowl.
    If it's an old toilet or a discontinued model and you're out of luck finding an exact size, look at the possibility of remodifing the drain.
    2,969
    Toto makes a 14" adaptor for their toilets. They come with a standard 12" adaptor, so the 14"er will need to be ordered separately.
    nova scotia, canada
    1,522
    your best bet is to go to a plumbing supply wholesaler which plumbers buy through. they would be the most likely to have it.. trying at a big box store is like trying to find a needle in a haystack
    Jun 2011
    208
    Bad Wife:
    I really don't understand why you can't simply install an ordinary toilet with a 12 inch rough in into the space you have. You don't need to replace a toilet with a 14 inch rough in with another toilet made for a 14 inch rough in.
    The "rough in" is simply the distance from the finished wall to the centerline of the toilet's drain pipe.
    So, if you install a toilet intended for a 12 inch rough in, it'll simply mean that you'll have an extra 2 inches of space between the toilet tank and the wall.
    That extra space is in fact somewhat of a benefit because it allows air circulation behind the toilet tank to prevent the wall from getting cold and condensation forming on the wall and damaging the plaster there. I've often seen deteriorated plaster behind toilet tanks because of condensation forming on the cold wall there.
    South*East
    1,220
    Quote Originally Posted by Nestor View Post
    Bad Wife:
    What also happens when you install a 12" rough toilet on a 14" rough you move the toilet forward into the room. From what the Bad Wife said she only has 26" of depth in the room. Most toilets are between 26" and 30" in depth, putting a 12" rough toilet on a 14" rough in would move the front of toilet even farther forward. I'm afraid she has a real problem finding a toilet to fit in such a limited space.
    John
    Aug 2014
    Smile Re: 14" rough in and require a small toilet
    Quote Originally Posted by badwife View Post
    I have the same problem.
    I found a 14" toilet with some character via www.gerber******.com
    This one also was regular height and NOT elongated. I don't care for the "comfort" height or the elongated.
    Lowes also had one, but it was quite plain.
    Dec 2013
    Montreal Canada
    211
    If you have a lead pipe as the toilet connection and have a foot or more between the floor and the 90 degree bend under the toilet then is something that MIGHT be possible. A really good plumber might be able to cut the hole in the floor towards the wall 2 more inches and bend the lead pipe that two inches and solder on a new lead repair. Then repair the floor where the old hole used to be. It does not have to be 100% perfect as it will be under the toilet. Then install a new toilet with a 12 inch rough in. This is only a job for a real plumber no handy men. Ask any plumbers that you are giving the job to if they have solder on a repair lead to a existing lead. I have done this modification myself, I worked for a very old plumbing outfit most house were 100 years or more old and we had to convert many toilet rough in with the tank on the wall and a flush bend elbow going to wards the bowl. Also I soldered on a repair lead about once a month so i was not worried and how to do this. As i said this might be possible.
    Dec 2008
    Midwest
    173
    Probably a reason it is roughed in at 14". Maybe a beam or floor joist, Box stores don't know about this go to an actual plumbing supply. they have several options, not that big of a deal really.
