    Aug 2011
    Default Replacing wall heaters in upstairs bedrooms
    We have an old house, built in 1920s, then moved to this location in the 1970s. The upstairs bedrooms are heated with gas wall heaters. They actually do a great job heating the rooms, but have a few minor problems. We asked the HVAC guy who was replacing our downstairs central unit about replacing or fixing them, but he told us they were actually not up to code now.
    What options do we have?
    5,792
    Default Re: Replacing wall heaters in upstairs bedrooms
    There are new gas wall heaters available here are a few-
    http://www.everyspaceheater.com/Natu...rs-C90837.html
    http://www.northerntool.com/shop/too...al-gas-heaters
    http://www.houseneeds.com/shop/eskab...eater_main.asp
    http://www.sears.com/search=gas%20wall%20heater
    Your old heater probably doesn't have an oxygen depletion sensor. Another problem is that some jurisdictions do not allow vent-less gas heaters, you would need to check with you local building department to see if they are allowed.
