    Aug 2011
    Default Heating/Cooling options
    My mother owns a 100+ year old home in northern Mississippi. It is approx. 2500 sf with 12 ft ceilings. The house sits 3 ft off ground on piers. She is considering installing central heat/air but wonders how that would work with the ceiling height. Any suggestions would be welcome and appreciated so that she can find the most efficient way to heat/cool the house. She is currently using propane heaters, as we are in the country, and window air conditioning.
    556
    Default Re: Heating/Cooling options
    Any procedure on determining which type of heating/cooling (HVAC) should be installed in a particular home has to begin with consulting the Yellow pages under "Heating Contractors" or "HVAC Contractors" and have at least 4 to 6 contractors come over the house to evaluate the situation & provide an estimate of what type of heating/cooling equipment would best suit the particular home; the estimate would of course include a written estimate of how much the work would cost.
    Don't ignore word of mouth, and community & business contacts that may have had the work done recently & can recommend a reliable contractor.
    It's important to go thru the process of getting as many estimates from different contractors as possible---this will tend to "dovetail" as the estimates come in, so that the cash estimate can vary considerably, and the choice of HVAC equipment will also dovetail so that a wise decision on both aspects can be more easily made.
    Jun 2010
    93
    Unless she's 12' tall what does it matter? As long as you have a proper heat gain calculated for proper sizing of the equipment and ductwork no problems..By the way, Hot air rises cold air falls...
    Tennessee
    1,778
    The most efficient system would probably be a ground loop (geothermal) heat pump. That would be very expensive and you need the land area for the loops.
    The most cost effective would be a gas pack. That is an all in one system outside the house. You want to specify all metal ductwork with insulation. A lot of the installers want to use flex duct, mice and rats love those installers. It provides them with a safe and warm home for the winter.
    If it is a two story house, a 105,000 gas furnace (150,000 btu on propane) with a 3 ton AC would be a good sized unit for the first floor. You might want to do a heat pump for the second floor.
