Results 1 to 8 of 8
    Wisconsin
    14
    Default Cement Porch & Stairs Repair??
    Hi,
    I'd like to repair this porch & stairs by just covering them up with PT deck boards & high Strenght glue.
    What do you think?
    Thanks
    John
    Eden, NC
    285
    Wink Re: Cement Porch & Stairs Repair??
    What type of material is there now. Could use close up pictures of the problem, hard to tell from such a distance.
    Calcats
    Wisconsin
    14
    Default Re: Cement Porch & Stairs Repair??
    More pics I took today
    The house is in Wisconsin
    The cement is very sturdy & safe
ID:	2329   Click image for larger version.
ID:	2330   Click image for larger version.
ID:	2331   Click image for larger version.
    May 2009
    Attleboro, MA
    26
    I wouldn't just rely on glue alone. If you must cover up the stairs, atleast use some tapcon screws to properly attach the decking down.
    For all of you Hidden Content needs in Massachusetts & RI
    If you're in need of a new Hidden Content or Hidden Content click here.
    Or if you looking for new Hidden Content
    Hidden Content
    Hidden Content
    Eden, NC
    285
    From the pictures, I wouldn't waste my money on the decking. The concrete is in bad shape and anything you cover it with will just help hold water and will allow more damage to occur when it freezes in the winter. I would either use the money to replace the porch and steps with new concrete or save the money until it gets worse and then replace it. You could tear it out and put up a wooden porch and steps, but the concrete will be there 15 years from now and the wood won't.
    Calcats
    Apr 2009
    158
    They do look like they're in bad shape, but you say they're very solid.
    I tend to agree with calcats, but I understand why you might want simply go over them. Maybe some patch work before you do that.
    I would also not go with adhesive alone.
    That said, I'm sitting here wondering if you would have issues with water freezing under anything you cover it with. If you place decking directly over, water will still get underneath and might lift the boards. If you put some strapping down, I'd still be concerned, but maybe that would be enough.
    I'm really starting to think covering it up may not be a good idea after all.
    Maybe a good mason might give you some ideas on how you could improve these such as patch up the cement and covering up with some brick-like tiles...sealing the tile afterwards to try to protect.
    Midwest
    179
    Old concrete is beyond repair. Remove and build new with wood or concrete.
    Sep 2009
    uk
    13
    Hack it up and redo mate
