    Aug 2011
    Default repairing metal porch floor on second floor porch
    I own an older two-story home with a second floor porch over a first floor enclosed porch. The upper porch decking is metal, perhaps tin. The metal flooring is rusting in spots and leaking into the lower unit. The upper porch has a door onto it and a full railing, indicating it was intended to be used as a porch. The pitch is from center to front and center to sides. I'm wondering if I can install a product similar to Lockdry watertight aluminum decking over the pitched floor and if so what preparation is required. Do I need to do a tear-off and replace the joists/change the pitch or can it be installed over the existing floor on the same angle? I hope my question is understandable.
    Default Re: repairing metal porch floor on second floor porch
    It sounds like you might be looking at re-doing the porch floor.
    If it's been leaking for a long time, you might have damages under the metal floor, so before solving the leak you will need to fix the subfloor and joists. That means, removing the metal floor.
