Thread: Outside steps
    Jul 2011
    Default Outside steps
    Help, help, help!!!! I have a bank (UGH) in my back yard with steps (3-4) leading up to another level of the yard (oh yes). These steps need replacing and I do not have a clue what to use to use to replace them other than paving bricks. I need something that is safe and not slippery and help on how to do this. The inital steps were not built very well and look atrocious!.
    Also, I would like to replace much of the foliage on the bank. At the moment the bank has low growing shrubs, and lirope (which is out of control). I would also like plants that would hold back water since I get a lot of run-off from the neighbors.
    Default Re: Outside steps
    for this you can do a few fifferent things, you can use stone, have a contractor build you concrete stairs, or with pressure treated 6x6's
    Jun 2011
    For the foliage, you might have to adjust the slope elevation if it is indeed run-off issues. Aside from some moss or pond grass, unless you have very thick plant growth near the water it will still have run-off.
    Be sure to use proper Hidden Content on your structures.
    Jul 2011
    Definitely you should build satires of stones, and bricks...
