    Jul 2011
    Default First floor powder room ceiling fan leaking
    I discovered my first floor power room ceiling fan leaking. The dry wall is dry and the water is coming from the metal housing. I checked my attic for leaks and there are none. The air conditioning has been on for quite a while. The bathroom is not used often, so we seldom use the fan. I don't know if condensenation has built up in the duckwork or what. Need help on where to start and what to look for.
    6,470
    Default Re: First floor powder room ceiling fan leaking
    There can be a few possible sources for a leak like this, and with so little information provided by you, it's almost impossible to pinpoint the exact cause.
    A potential starting point: shut the main water to the house and see if the leak stops.
