Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. #11
    7,762
    Default Re: shower hot and cold are reversed
    You know, vents were ment to go outside the structure, so continue the one you have outside. And yes, it involves cutting the exterior/roof, then sealing it.
  2. #12
    South*East
    1,252
    The best solution would be to vent it through the roof. A studor vent will work but by code it must be accessible. Even if you get the vent into the attic space and put a studor on it there that would be a much better situation then you have at the present time. Can you tell me how this happened in the first place?
    John
  3. #13
    Aug 2012
    Thanks much for the help on this. One point of clarification, it's only necessary to simply turn the stem. No need to try to turn the whole cartridge like I started to do.
