    Jul 2011
    Exclamation Triple 3-way switch in single yolk
    I have an old triple 3-way switch in a single yolk and the middle switch is broke. Any idea where I can get a new one can only find Dual 3-way.
    Columbiana, Alabama
    843
    Default Re: Triple 3-way switch in single yolk
    I suspect you're having trouble finding a tripple switch on a single yoke is because if such a switch was mounted in a single gang box, the legal box fill would most likely be exceeded. So, it's not being manufactured.
    Can you live with a double switch and have two lights come on together?
    Maurice Turgeon, http://thesemi-retiredelectrician.com
    Feb 2011
    Brown county, Ohio
    52
    or if the location permits you could cut in a three gang box to replace the single gang box, might have to lenghten the wire some with wirenuts
    Aug 2011
    Northern Indiana
    103
    Try googling 'despard devices' to see if that is what you need.
    Sep 2009
    jersey
    174
    Quote Originally Posted by haltthree View Post
    Home Depot
    Ace Hardware
    Lowes
    There pretty common in most parts.
    Help us name our new Hidden Content
