Results 1 to 8 of 8
Thread: kitchen floor
    Dec 2008
    12
    Default kitchen floor
    I am remodeling my kitchen and have taken down a wall to include a small addition that was built by the previous homeowner as a TV room. the problem I have is that the sub floors from their addition and the original kitchen is about 3/32 to 1/8" of an inch different (lower). I was trying to think of a good method to raise the level to make them even as we are planning to put down a prefinished wood floor.
    What I was thinking was to put enough layers of rosin paper on the 10x8 lower section to make it level and then put 1/4" luan over everything. Will this feel spongy?
    Anyone have any good suggestions since the difference is so small.
    Thanks in advance.
    6,613
    Default Re: kitchen floor
    Even though the difference between the floors is only 1/8" you have the right idea.
    I would use simple vinyl squares (I know, lots of folks hate them) as a build up measure. Just make sure that the floor is nice and leveled before the new wood floors goes down.
    Dec 2008
    12
    Thanks,
    I thought about that too , I was hopeing for something with less labor. Maybe I can have the wife do it?
    5,806
    1/8" Luan paneling put down with screws..
    Jul 2011
    Hello...
    dj1, your suggestion to remodel the kitchen floor is very good. I like to see that all of you have a good discussion in this topic...
    2,128
    As long as nothing is still moving around, just float it out with level-patch like you use under vinyl flooring. Use the recommended underlayment and the rest is a snap (together). Arrange the flooring joints where they won't land on high spots (they will open) or low spots (the joint may break with a load on one side). With engineered flooring keep all the humps and dips as gradual as you can- in an old house having a dead-flat floor underneath isn't always an option.
    Sep 2011
    53
    wooden or marble vinyl tiles would be great for kitchen flooring..
    Sep 2011
    United States
    Quote Originally Posted by comsec1 View Post
    Thanks,
    I was thinking that your post was intended as a joke. :-)
