Thread: Sewage Pump
    Jul 2011
    Default Sewage Pump
    Hello,
    My home is located below the city sewage system and as a result I have a temporary storage tank and pump that pumps the sewage to the main sewer line.
    I didn't think about it when I was purchasing the house and did not receive any maintenance instructions and I got to thinking, do I need to treat this temporary tank like a septic system and treat it with Rid-X? Any other maintenance I need to be performing?
    Any advice is welcomed,
    Thanks.
    South*East
    1,259
    Default Re: Sewage Pump
    The tank should be cleaned, similar to a septic tank. How often depends on the usage and the size of the tank. They will get a soap and grease buildup than can cause problems. I would call a septic company and have it cleaned. He should be able to tell you how often it needs to be serviced.
    John
