    Jul 2011
    Default Painting over wall tile adhesive
    Can I pop the tile off of our bathroom walls and apply a texture paint over the adhesive, then prime and paint or is it wise to sand the adhesive?
    Default Re: Painting over wall tile adhesive
    If you want it to look good when you're finished, you're going to need to remove and/or skim coat the adhesive and create a flat surface to work from. From there you can texture and paint with acceptable results.
