    Aug 2009
    19
    Default Outdoor faucet leaks with back pressure
    I have a a faucet with a water timer attached to water some plants once a day for a few minutes. When the faucet is off there is no leak but when I turn the faucet on with the timer off then the faucet leaks just below the handle. Even turning the handle just slightly causes a drip if the timer is off.
    What should I do to fix the problem?
    South*East
    1,259
    Default Re: Outdoor faucet leaks with back pressure
    Depending on the faucet there should be a packing nut just below the handle, try to tighten it, this may solve you problem.
    John
    Aug 2009
    19
    Thanks, that worked.
