Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. #11
    7,353
    Default Re: old dirt basement
    Quote Originally Posted by Nancytsimpson View Post
    We are moving into a house built in 1883 with dirt still in the basement. The precious owners said to keep a bulb burning 24/7 to keep mold from growing. True or false? I'd rather save the electricity. Thanks for your help.
    Running a fan to move the air around and installing a moisture barrier on the dirt may work better.
  2. #12
    2,478
    The bulb may provide a nominal amount of heat to assist drying but with one bulb alone it would take lab-grade instrumentation to detect the difference. Just lay a vapor barrier then ventilate it and you should be fine. "Gravity ventilation" may be enough; a high air outlet to the outside and a low air inlet directly across the area. If could be manually or thermostatically closeable during winter months to save with heating. If not, continuously powering a small fan system will cost very little, less than a 100 watt bulb, and be more effective too.
