    Jul 2011
    Default Protection from thorns
    I need protection for my hands and arms up to my elbows when pruning roses or picking or trimming back blackberry bushes. The problem that I have found is that when the protection from a product is good, the dexterity needed in my fingers is not.Also,I live where it is very warm and working in gloves and/or arm protectors that are quite hot can be quite uncomfortable. Any suggestions, methods, products, etc. would be greatly appreciated. Thanks. Diane Schulte
    Tennessee
    1,995
    Default Re: Protection from thorns
    I used to recommend pig skin gloves for dexterity but now, you might want to go to a car parts store like AutoZone and check out some of the new mechanics gloves. Can't help you with the arm protection though.
    7,762
    Roses are nice, but don't get too close...
    I use "long distance pruning", using a bypass lopper (for big branches) and Corona or Fiskars shears (for small branches). I don't use gloves, because I like to work without them better. I pick cut branches from the ground using the same tools. This means that I don't use a hand pruner (or is it prunner?) - the one with the short handles.
    Once you trim the branches, you can start smelling the roses !
    Jun 2011
    17
    Try chopsticks! That is, if you are enough adept at using them. You could even just try to use a thin stick just for the sake of separating the stems. You could probably use the arm protection but go glove-less (unless you use your hands to remove thorns)
