Poll: Were you satisfied with your electrical contractor?
Be advised that this is a public poll: other users can see the choice(s) you selected.
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. #11
    7,086
    Default Re: Electrical Advice
    I agree, but most DIYers seem to have Multi-meters because they can pick one up for less than $20. A "wiggie" is all that I use now that they have a continuity feature. Only use Multi for DC circuits.
    Whatever happened to testing a wire on the end of your tongue? You wanna get wiggy with it, that's gonna do it for ya!
    For those that don't know me, this is a holiday weekend, there may be some adult beverages involved with this answer, and above all that I'M KIDDING!!!!!!!!!
  2. #12
    Jan 2011
    Columbiana, Alabama
    721
    In defense of the "chirpers" I wouldn't leave home without one and wave it all around a box before I stick my fingers in there.
    But, only after I've used my wiggie and even then I'll take a large screwdriver and touch all the hots to ground.
    Even then I've made wire strippers out of many expensive lineman pliers when cutting and energized cable. Even 15A circuits carry a heck of a punch!
    And, I can't count the number of times when I had to remove the face off my first multimeter to straighten the pointer after measuring a high voltage (or current) on the low range.
    Maurice Turgeon, http://thesemi-retiredelectrician.com
  3. #13
    5,804
    Semi, that's how I learned to weld. My welding still looks like and accident.
  4. #14
    Jan 2011
    Columbiana, Alabama
    721
    Ever made up a low voltage connection for your sidewalk or driveway landscape lighting and wish you could make it waterproof?
    I started twisting the wires together as tight as I could get them then, using an ordinary wirenut turned upside down I dabb PVC glue into them. Connections last forever, even under water!
    Also, PVC glue dabbed inside a weather proof box will seal the treads better than anything else I've found.
  5. #15
    6,598
    Semi,
    Using some PVC cement glue in ground wire connections is a hell of an idea, even though I think that landscape lights are going wireless these days.
  6. #16
    Jan 2011
    Columbiana, Alabama
    721
    Do you wish you had some cutting oil to cool a drill bit, band saw, hole saw, tap or die and get better performance?
    The best and cheapest oil is bacon grease, only problem I can see is it makes you want to take an early lunch!
  7. #17
    1,629
    I wanted to replace my ceiling fan so I removed the connectors on all the wires. There are 17 wires in the box. Which ones do I need to connect to make it work again? Oh, by the way, my refrigerator stopped working so I need to know how to fix this right away before my beer gets warm. I don't have a digital camera so I can't take a picture.
  8. #18
    6,598
    Fencepost,
    1. You're in luck. Casablanca fans are 50% off for father's day. Reg. $3999, now only $1,999.
    2. RR has top of the line ref. also for 1/2 off for mother's day. Reg. $4999, now only $2499.
    If you don't know where to find them, send me a cashier's check and I'll make sure they are delivered on time...
