Thread: Blocked vent?
    Jun 2011
    Default Blocked vent?
    Sometimes when the washing machine is draining, the toilet starts "glub, glubbing". I have also heard noise from the washer drainage pipe when the toilet is flushed. Is a blocked vent also causing this or is it something else?
    South*East
    1,253
    Default Re: Blocked vent?
    It sounds like a main line stoppage. Vents if piped properly get plugged very seldom. The main line may not be totally plugged, but in either case the line should be snaked.
    John
