Thread: septic system
    Jun 2011
    Default septic system
    We have a septic system. Sometimes the ground is wet in the yard in that area. It's not sewage, just water. Mostly happens when doing a lot of laundry. Is this common or do we have a major problem?
    South*East
    1,257
    Default Re: septic system
    Get the septic checked as standing water is not a good sign. I also replied to you other post. It sounds like your other problem is related to your septic problem. Snaking will not help if the septic is failing.
    John
    2,737
    It's likely that the soil around and over the drain field is too compacted to leach properly. If the effluent can't go out it goes up. That happens a lot here with the high clay content of our local soil. Then proper fix is to remove the soil around the drain field and replace it with better soil- you may have to dig the gravel out and clean it first. If you have room a cheaper fix is to extend the drain field to a new non-compacted area but since you're going to be digging up the yard anyway I say fix it right. I'd avoid the new wrapped 'soil pipe' even if it meets code with soils which don't leach well- better the old gravel bed with soil fabric to keep the dirt out in places with compaction issues as it gives the effluent more room to flow before saturating.
