Thread: Epoxy
    Jun 2011
    Smile Epoxy
    Is there an Epoxy coating that can be used in Florida to paint an old driveway that already was painted with regular paint?
    Jun 2011
    208
    Default Re: Epoxy
    Novlet22:
    There's no epoxy that will remove the old paint and stick to the concrete. The epoxy will stick to the old paint, and if that old paint decides to let go of the concrete, it'll take the epoxy off with it.
    Do you know what kind of paint is on the concrete now? Also, do you know how long that old paint has been on, and are there any areas where it's cracking and peeling off?
    You should also keep in mind that a driveway with "regular" paint or epoxy paint on it can be awfully slippery when it's wet.
    2,743
    Default Re: Epoxy
    Any surface applied material is only as good as the surface under it. In my 30+ years of construction work I've never seen new paint properly applied fail, but plenty of old paint underneath it come off. Epoxy will work for you for as long as what's there now is good- when it fails there goes your epoxy too. Epoxy will last longer as long it's there which makes it a better choice.
    1,950
    Default Re: Epoxy
    Those 2-part epoxies that are used for garage floors are never used for exterior surfaces. Indeed, the epoxy will always stop exactly under the overhead door.
    Further, the one thing that will prevent a guarantee by the epoxy coating company is the presence of moisture weeping up through the cement. The companies that do garage floor coatings will always check for moisture. The simplest test is to tape down heavy plastic for 24 hours and then pull it up to see if condensation is underneath.
    Also, epoxies that are wet become extremely slippery. It is possible to add a fine grit to the epoxy to give better traction.
    Jan 2015
    29
    Default Re: Epoxy
    No luck with your request. All bad. If you want a refresh to your driveway it is not too hard. Either hire out to get it sandblasted or if you want to do yourself, get a good local big box store paint stripper. After that pressure wash it very clean and let dry. Get a good concrete stain in a color you like and a non-slip sealer. Both can be found on the web if you don't have a local concrete supply house. Very DIY if you are up for it. If you are not up for it, many local decorative contractors deal with staining like this.
