    Aug 2009
    17
    Default Turn off one device when another goes on
    I need to turn on off one appliance when another turns on and vice versa automatically. Both use 12v transformers and do not have on/off switches so cutting or providing power is all that is needed. I could use a timer on each but would like a more elegant solution.
    Columbiana, Alabama
    706
    Default Re: Turn off one device when another goes on
    IT, do the appliances turn on/off automatically or are they controlled manually.
    If the latter, a simple 3 way switch in a junction box would work.
    If the former, a current sensing relay will be required, and a larger control box.
    Maurice Turgeon, http://thesemi-retiredelectrician.com
