Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    Default Re: new switch and fan
    You're welcome -- post back and let us know how you make out.
  2. #12
    Jun 2011
    7
    hello, one question before I go any further mounting then fan. I now have constant power at the outlet which is good. If I understand you I am leaving the wiring at the switch the I had originally described to you in my intial post.
  3. #13
    Quote Originally Posted by mase View Post
    I want to install a new ceiling fan and light where there isn't one now. I have a wall switch that controls an outlet. I want to run the new light off of a new switch at the wall and have the fan controlled by the pull chain. The wall switch I want to tie into has 1 black and 1 white wire coming in (no ground). I wired the in the 2 switches and power at all connections in the box but the wall outlet is not woking. I haven't put up the new fan yet until I get the wiring correct. Where am I going wrong?
    white-white
    incoming black pigtailed to the bottom **** connections on each switch
    outgoing black to top **** connection of switch closest to door
    red to top **** connection on switch away from door
    ongoing ground to ground on switch farthest from door
    no incoming ground from walloutlet
    Good stuff !
    Yes -- wire up the way you initially posted.
    One thing though --- initally you indicated there are two switches -- one originally that controlled the receptacle --- another you added for the fan light ?
    You will use one switch to control the light -- no problem.
    However,the other switch really isn't needed since the fan is to be turned on/off by the pull chain. This would normally require you wire the fan hot to constant supply current --- which would be the black at the switch that you recently reconfigured.
  4. #14
    Jun 2011
    7
    Thank you canuck. Everything is working properly amd I let the extra switch control the fan. Thanks again.
  5. #15
    mase --- you're welcome.
    Glad it all worked out and thanks for posting back with the result.
