Results 1 to 10 of 11
    Jun 2011
    Default Drywall over painted block
    Can someone tell me if it acceptable to install drywall directly over painted masonry block with adhesive in lieu of firring strips?
    3,201
    Default Re: Drywall over painted block
    You can IF
    1- This is a dry location and there is NO risk of water getting to the back side of the drywall
    2- You have no desire to remove the drywall in the future. Whomever gets to remove this drywall will curse the day you were born. Furring strips help solve this problem
    3- The block is plumb and straight enough to get nice drywall joints. Furring strips help solve this problem
    4- You have no desire to attach baseboards, crown moulding, or trim. Furring strips help solve this problem
    5- You have no desire to have electrical, plumbing, audio / video. Furring strips help solve this problem
    6- You have some way to get the drywall panels to stay where you want them while the glue sets. Furring strips help solve this problem
    Why do you want to do this?
    Now wait a minute, are you saying that furring strips will F-up a plumb and straight wall?
    I know what you meant, but it bears fixing for clarity.
    3,201
    I am thinking about leaving it, just to see if anyone else is paying attention.
    Jun 2011
    This is an existing finished area being used as a church nursery. Existing walls are painted block (many coats). The existing doors are trimmed with 3/4"material and all electrical is existing and fine where it is. The purpose of the drywall is to update the look of the block. This area also has a drop ceiling. If I use firring strips I will have to re-trim the doors and extend the jambs. If I apply the drywall directly, I will save the cost of this as well as the cost of applying the firring strips.
    Rather than overlay the walls, I think I'd be inclined to skim coat them with either plaster or drywall compound to smooth the surface and mimic drywall. It would be a whole lot easier, cheaper, and cleaner to do.
    Jun 2011
    208
    Two easy ways that any newbie can skim coat any wall:
    1. Use a "V" notched adhesive trowel to spread joint compound on the wall, and allow to dry. Then, holding that same trowel upside down, fill in the trowel ridges with the un-notched side of the trowel. The result will be a uniformly thick layer of joint compound on the wall.
    2. Use a "V" notched adhesive trowel to spread joint compound on the wall. While the compound is still wet, mist it with water using a spray bottle, and trowel it flat using the un-notched side of the trowel.
    In either case, it's best to first paint the wall with white wood glue diluted in enough water to make it into a paintable consistancy. Allow that dilute glue to dry on the wall. The moisture from the joint compound will re-activate the glue, causing it to bond the joint compound to the wall. For a Cadillac job, one could use concrete bonding agent instead of white wood glue. Concrete bonding agent has a "window of opportunity" during which wet material will re-activate it's adhesive properties. Once that time window has closed, concrete bonding agent becomes unaffected by moisture. I'm thinking that if moisture coming through the block wall was a problem, it would mucked up the multiple coats of paint on that wall by now. If moisture migration through the wall isn't a concern, then white wood glue won't re-emulsify and drop the skim coat of joint compound onto the floor.
    Aug 2009
    Ladson,SC
    192
    I would agree that skim coating is acceptalable I would stay away from the dry wall product and use an Acrylic Plaster applied to the block.
    Check on One of these products.
    Variance Acrylic Finishes.Located in Albuquerque,NM
    Litex Incorported, Fort Lauderdale, FL
    SAFRA veneer plaster products
    Master of Plaster
    All the above can be textured or applied smooth with color no painting required.
    Can be applied over a painted surface some require a bonding agent that will come with the product that you select.
    I say no Joint Compound based on my experence as a plaster.
    75 % of my work comes from the use of Drywall product applied over substrates that will last from 5 to 20 years than I get to due high dollar repairs.Been doing these repairs for the last 35 Yrs.
    Jun 2011
    Great ideas! Thanks!
    1,522
    im with sprucey on this one, definitely just get the wall parged
