Results 11 to 20 of 24
  1. #11
    7,972
    Default Re: portable dishwasher
    I haven't.
    You need to go to your profile and allow Private Messages. That way we don't have to disturb the natives with needless banter ...
  2. #12
    6,017
    But Sprucey you always post needless banter.
  3. #13
    7,972
    Words hurt, Mister! You take that back! Right NOW!
  4. #14
    6,017
    But if I take it back, that would just be needless banter.
  5. #15
    7,972
    That's it! I'm going to the pub and putting my bill on your tab!
  6. #16
    Jun 2011
    Delmarva
    26
    hi all, to clarify, yes i currently have a portable dishwasher and i wanted to remove the old unit and reinistall a new internal unit into the old shell. thanks all for help. ill probably end up having to get a new portable which sucks since their so expensive.
    ill see if i can get pics later today for you all.
  7. #17
    Jun 2011
    Delmarva
    26
    Question Re: portable dishwasher
    ok i got pictures last nite
    geres the diashwasher and what the back connections look like
    http://imageshack.us/g/836/img20110622215917.jpg/
    http://imageshack.us/photo/my-images...0622215936.jpg
  8. #18
    7,972
    Question, why do you need a portable when it's permanently affixed to the plumbing? I would be inclined to buy or build a cabinet (matching the existing kitchen units ) to attach to the wall, then install a standard dishwasher in it. You'd need about 30" or 32" between the stove and the door to fit this set-up, but it would be a lot cleaner installation.
    The cabinet is basically two end wall pieces, which can be purchased premade, with a piece of counter over the top of them. You could probably salvage the butcher block top from the existing DW to use as the countertop. This would be cheap and easy, probably more so than trying to gut the portable.
    As far as gutting the portable, the outer case should be attached around the front and back with a few screws, then lift off. Trouble is, the new unit isn't going to have the mounting flanges that the old one does, so getting the case to align and fit properly will be a chore.
  9. #19
    Jun 2011
    Delmarva
    26
    what ure saying makes sense. ill measure the space tonight and see how much room i have thanks
  10. #20
    7,972
    You're welcome.
    This is why it's always important to give as many details as possible and pictures if possible. When we have a clear idea/view of what's going on, it's much easier to suggest remedies to suit your needs.
