Thread: tube
    Jun 2011
    Default tube
    my tube has a leak, i replace the seats in both hot and cold water an it still leaks i need some help, i tryed everything.
    6,762
    Default Re: tube
    Have you checked the stems and washers?
    Assuming that you correctly installed the new seats, the trouble could be in the stems or the washers.
    Jun 2011
    Los Angeles, CA
    11
    Default Re: tube
    Tub I believe....
    When replacing seats you must use tephlon tape around the threads of the seats, 3 or 4 wraps should be good, tighten securely.
    Also as the previous gental man mentioned, when repairing valve body and stems, always - replace seats, seat washers, securely tighten seat washer screw also.
    Without tephlon tape on seat threads or securely tightening seat washer screw, you can get a by pass of the pressurized water beneath seat or through the washer. Hope this helps.
