    Jun 2011
    Question Odor in basement room
    Hello......
    I have a rental property that has a musty almost STINKY odor in one of the basement rooms. It was just brought to my attention when the last tenants moved out ( they had been there 4 yrs so who knows how long this has been happening ) ......
    Our first thought was that they carpet was soiled in some way perhaps by a cat. We had a contractor pull up the carpet but he says the smell is not in the carpet. We are going to let the concrete floor air out for a day or two and see if the smell is still there. If it is, I have NO IDEA what direction to go in next. Could a dead animal be in the walls ? But then the walls must be concrete if in basement, right ? I just have no idea what to do. Anyone ever been in this predictament and / or have any suggestions ? The new tenants won't let their children sleep downstairs until we rectify this. Help !!
    thanks,
    Sheeluhh
    Jul 2009
    172
    Default Re: Odor in basement room
    A partially blocked sewer drain is the best guess I can come up with.
    If sewerage is backing up in the main drains, you'll get that characteristic lingering odor.
    Try finding a sewer cleanout opening near where the sewer lines enter and go thru the foundation & open it; connect a garden hose to the nearest faucet & run the water full blast for 5 minutes to see if there is any improvement.
    7,334
    I'm thinking the same way, plus: check the sewer line cleanout cap. If it's ineffective, replace it.
    Sep 2011
    53
    Just like in what I've posted earlier in another subforum of TOH, try using charcoal. It is a tried-and-true odor removal technique that can be used to deodorize any powerful chemical odor.
