View Poll Results: What would you put in your "forever house" under porcelain tile to be H2O proof?
Voters
1. This poll is closed
  • Noble TS
    0 0%
  • cementboard
    0 0%
  • denshield
    1 100.00%
  • something else- tell me what, please
    0 0%
Multiple Choice Poll.
    Jan 2011
    8
    Default What do you put under porcelain tile when it has to be waterproof?
    It's your forever house, and you're going to live at least 20 more years, with teenagers using your shower (hours at a time), the lady of the house taking long soaks in the seperate tub. Occasionally todlers will slosh gallons out of the tub onto the floor.
    What do you use on the floor?
    Can't use Kerdi, porcelain requires latex modified thinset. What do you put over the plywood floor to waterproof? Redgard? Noble TS?.
    What do you make the walls behind the tile out of? Some of you love Denshield and some say it turns to mush. Mixed reviews on cement board. You want it waterproof but Remember plumbing leaks can happen behind the walls too. What would you use in your forever house?
    (guess what I'm remodeling due to massive waterleak behind the walls)Sign me:
    About to remodel the Forever House
    1,354
    Default Re: What do you put under porcelain tile when it has to be waterproof?
    They install porcelain tile all the time over Kerdi w/unmodified thinset, So I don't know why you think otherwise. If you want to ensure a good bond, backbutter the tiles.
    Casey
    3,155
    Porcelain tiles have been installed with non modified thinset for centuries.
    Porcelain can be set over kerdi with no issues. Laticrete hydroban and hydrobarrier are also excellent waterproofers.
    nova scotia, canada
    1,522
    denseshield on the wall and kerdi on the floor, no issues on any bathrooms other than the odor after chili night
    7,651
    I agree with all of the above !
