Results 1 to 10 of 11
    27
    Cool HVAC guy installed without permit no cold air etc...help!!
    We hired an HVAC guy who installed it for us. over 3 weeks. here are my Qs:
    It took the whole day to bring the inside temperature down to 70 F. The air that comes out is not cold enough and the a/c stops only for 5 min and run none stop for 20 min. the outside temp was 84-89 F. to maintain the temp inside at 72F. our House is 2000 sq ft of split with one high cathedral sealing.
    Also the HVAC guy never took a permit out. when we asked at the finishing of the work he said he will get it and give it. can this be done. We went in the attic and saw a very sloppy job--they didnt tie the insulations even to the ducks ( the foil thingys) the attic fan was broken and they were to fix it. NOw they cant do it since they placed the unite just below it and therre is not space.....we really want an inspection done asap but since he did not take the permit out I am not sure how we can get the inspection? please suggest any solution. what is the penality of getting work done without township permit....
    Also the come a strange sound when the unit turn on.
    Please helppppppppppp
    6,936
    Default Re: HVAC guy installed without permit no cold air etc...help!!
    Can't advise too much without knowing what the stipulations of the contract were. Technically, a permit must be pulled and several inspections occur during the course of installation.
    Technically speaking, regardless of contract, a permit would be required, and if one was not pulled, then likely corners were cut and you paid top dollar anyway. Contact your building authority and apprise them of the situation, the brunt of the fault will lay with the "contractor" who misinformed you, didn't pull the permit, and did the job without inspection.
    How all this will work in your favor will depend on the will of the gods and the court system in your area. Where I'm at, the contractor would be seriously screwed!
    6,304
    Things like this happen all the time, and this is how to remedy the mess:
    First, you will need to go to the building department in your town, explain what happened and see their reaction.
    Basically, the law can't help those who don't follow it...or break it.
    Second, they will probably tell you to pull a permit, or to get another contractor to come in, pull a permit and take over the job. Be careful here: many contractors don't like to step into someone else's mess, and if you find one who will, get ready to pay. Oh, I almost forgot, you will be kindly asked to pay a penalty/fine. How much? you will be at the mercy of the city.
    Then you can deal with this unqualified a/c man. If you have something in writing, you can go to court or the state board. If you're lucky there will be some bond money to pay for damages, but don't count on it.
    27
    Thank you so much for quick reply posts...they are very helpful. I have always turned to this message board--a life saver.
    We have asked the HVAC guy to give us the permit. We plan to give him this long weekend and up till Tuesday. IF we dont hear from him we will go to the building administrator in the town, explain the situation pay the fine etc.and do as suggested
    This guy has done three houses next door over last 5 years and we have asked the people how the A/C is working and all. Mind you all houses were done before new occupants so they have no idea if the owns pulled permits etc.
    They have no complained though. so hopefully there are no major problems and dangerous ones ( keeping my fingers crossed)
    Thanks any ways and i will keep you all posted.
    6,304
    Oh, and another thing:
    Ask him if he would like to get a chance and fix the problem, since he has done some decent work in the area.
    Sometimes a contractor will do that rather than suffer the consequences.
    But be firm on the time you give him and don't let him string you around.
    6,936
    I would second this idea. Unlike many contractors, I don't have the dim view of unlicensed contracting or seemingly "bad" contracting that many of my fellow tradesmen have. That does NOT mean that I'm tolerant of bad workmanship or screwing the public, I will be the first to say burn them at the stake if this is the case!
    It is possible that the person you hired had a bad day or their employee had a bad day and something went awry. Give the guy a chance to fix the mistake with the consequences known. If they don't, go to your local authority, both the permit office and the contractors board. If they do, let the matter drop, but let this be a lesson learned to do a little checking into the people you hire in the future.
    Again, I have no judgment on you or the person you hired, but shoddy workmanship is NEVER permissible!
    Jul 2009
    Northeast
    661
    I agree with everything that Sprucie say's but would like to add that if a worker is having a bad day he should get off the job and go home. If the owner of the Co. knew this then he should have gotten him off the job, as Holmes would say " Unacceptable"
    Good Luck
    27
    Angry Re: HVAC guy installed without permit no cold air etc...help!!
    Okay its tuesday and the contractor did not call back!
    Can someone tell me what it means if the HVAC starts to run ever 3-5 min. and runs for 20 min to maintain 78 F outside is 96 F
    Do you think the 3 Ton unite maybe small for our space?????
    What can we do now the eletricity bill will kill us like this right?
    Can the contractor be asked to replace it with a 3.5 ton...
    what can I do any other remedies....HELP ....GOING CRAZY (*&*&^%$%
    May 2011
    251
    First where do you live? 96F is at or above the design temp for many parts of the country. Meaning a perfectly sized unit will run continuously at 96F. Most people are used to oversized units.
    However it should be able to pull it down to at least 75F after a couple hours.
    A 3.0 Ton in most regions would be about right for 1500-2000 sq feet depending on insulation, # windows, how well sealed it is and how much shade the property has in the afternoon.
    If the air isn't cold, the fan speed could be set too high. IF it has a 4 Ton blower, it should not be set on the "high" speed. Rather Med-Hi. IF it's Vairable speed, the dip switches need to be set correctly.
    2nd, something could be incorrect with the amount of refrigerant charge, the size of the lineset, how the lineset is routed or it could be the expansion valve is partially plugged or if it has a fixed orifice, not a TXV, it may have the wrong size installed.
    At some point you may need to bite the bullet and find another contractor to check the unit out. Send a letter to the installer by certified mail asked for them to respond within 2 business days and schedule a service call within 5 days. If they don;t respond go somewhere else and have it diagnosed.
    21
    I wonder what happened =(
