Results 1 to 10 of 11
Thread: Excessive gap
    18
    Default Excessive gap
    I have a couple of doors that are out of square. One is an exterior door and the other goes to the garage. Most people in this situation are complaining about the door not closing or dragging the floor. I have the opposite problem, the gap between the door and frame is too large for the door to seal properly. How can I fix this?
    1,522
    Default Re: Excessive gap
    you should be able to adjust the sweep on the door, normally there are screws that can be loosened to allow it to slide up and down otherwise the sweep may be wearing out then its a matter of replacing it... a sweep will run you about $15 or so at any bigbox
    18
    A door sweep isn't going to fill the gaps around the door but thanks anyway.
    1,522
    in that case you may want to remove the trim and reinstall the door and shim it so its square again. with it being out of square its just going to bind up on you in the warmer months anyway making it harder to open and close once it swells with the humidity
    7,762
    Jkirk is absolutely correct here: resquaring the door and the jamb is the best remedy.
    When removing casing and trim, use caution not to cause damages. After the door is squared, reinstall insulation, trim, casing and caulk.
    I just resquared an entry door last week - now it works like new.
    Sep 2009
    florida
    598
    I'm with JK on this one. Remove the trim on the hinge side & see if the door was ever shimmed correctly. If it isnt shimming behind the hinges can correct the situation at times. Make sure you add at least one long screw into the hinge to keep the door from sagging back down. Depending on how bad the door is sagged you may be able to shim the hinges out some. I cut up a plastic milk jug the same shape as the hinge to ship the door over. The plastic will never rot like cardboard hinge shims.
    Gizmo
    Hidden Content
    Hidden Content
    1,522
    good idea about the plastic milk jug for shim material gizmo. ive just been using playing cards or the package from hinges for shims
    Sep 2009
    florida
    598
    jk I use to have plenty of Milk Jug Shim Supplies already cut out. Once you have the pattern cut out use a old fashion paper hole punch for the holes.
    http://www.google.com/products/catal...d=0CFAQ8wIwAA#
    Gizmo
    Hidden Content
    Hidden Content
    1,522
    im going to have to jot this one down in my notebook of tricks and start implementing it
    Sep 2009
    florida
    598
    jk..I wouldnt doubt if Norm & Tom put that little recipe in there bag of tricks for a show/magazine topic under Green Building.
    Thats ok if they will demonstrate the Miter Master Plus on the show also.
    You can make your own Milk Jug washer/spacers with different size's using hole saws when in a bind also...
    opps Gizmo's spamming.......
    Gizmo
    Hidden Content
    Hidden Content
